Power major
charles
05-27-2003 04:24:42
Apologies if this is a duplicate
My hardworking (300 hours per year ) Tractor leaks a small amount of Gearbox oil from the clutch housing,the g-box oil level does not change noticeably.The oil is clean ,am i right in hoping that the oil is simply dripping from the shaft harmlessly,rather than contaminating the dual clutch?I would rather not split the tractor if possible
thanks in advance
Paddy
05-28-2003 01:17:22
 Re: power major in reply to charles, 05-27-2003 04:24:42
Unfortunately that will be an oil seal that can only be accessed by splitting the tractor. If its only a small amount, i wouldnt worry about it, if it starts becoming a problem then you'll have to look into getting a splitting rail.
