Ford Major Injector Pump
Dugald
05-29-2003 09:21:03
I think I have a problem with the Simms injector pump. Tractor is approx. 1955 Major and will fire on ether. Fuel is clean and bled to the pump, air flow clear. Kill linkage to injector pump forward. Fuel bleeds from pump but won't make it to injectors when cranking. No pressure out of pump. Tractor sat all winter outside covered and there was water in fuel tank and water and contamination in sediment bowl, now bled to clean diesel. Have removed injector pump and taken to local tractor shop but am wondering if pump is likely problem and if rebuild or replacement pumps are available. Any help much appriciated.
Peter, U.K.
05-30-2003 02:04:38
 Re: Ford Major Injector Pump in reply to Dugald, 05-29-2003 09:21:03
Dugald, There isn't much you can do with a fuel pump other than take it to a specialist fuel injection engineer who will have the necessary expertise and equipment to test it and correct any fault.
Paddy
05-31-2003 03:47:04
 Re: Re: Ford Major Injector Pump in reply to Peter, U.K., 05-30-2003 02:04:38
Are you sure you bled it properly? What id do is LOOSEN (not remove) 1 or 2 of the nuts at the injectors on the side of the cylinder head. Pull out the stop control and crank the engine and you will see the fuel trickle out if the pumps working. This way you will see if fuel is getting thru to the injectors. I normally include this as part of the bleeding procedure. Good luck
Bob
06-12-2003 22:20:37
 Re: Re: Re: Ford Major Injector Pump in reply to Paddy, 05-31-2003 03:47:04
I have had these pumps apart and found that most are easily fixed I would love to tell you how but If you don't know injection pumps well it won't help you any. I worked on Volks Wagon DSLs for years. Email rpawlukovi@mail.com maybe I can help put fordson on the subject line
Mark Davis
03-04-2004 19:27:42
 Re: Re: Re: Re: Ford Major Injector Pump in reply to Bob, 06-12-2003 22:20:37
my ford major with a simms pump, runs but not good. only one injector will return fuel. and if
I try to throtle up it will pop and bang in the ex. I installed new injectors and repaired the air lines to the air intake. any help would be
great
