Timing 1954 fmd
JOHN
06-06-2003 06:27:55
About 2 mos. ago I thought I might try and mess around with the timing. I removed the claw bolts and turned the crankshaft pulley. Well now the tractor fails to even start. And I have no idea how far out of whack i have it. I am looking for some help to get it back. Also, the reason I attempted this is because I had found that over a period of time i was loosing power and it just seemed to run bogged down. It used to run very strong. I thought it might be the timing or injectors were dirty. Any advice would be appreciated.
Thanks, John
tooly
06-07-2003 17:22:22
 Re: timing 1954 fmd in reply to JOHN, 06-06-2003 06:27:55
this should help..... .remove rocker arm cover and turn engine over by hand.....watch valves at #4 cyl. when exhaust just closes and intake starts to open, then #1 is in position to fire,
now aligne timing marks on crank shaft.should be a notch on the pulley and a stationary pointer to aligne.
now line up mark on pump coupling with stationary mark on pump and instal pump.
after doing this turn engine over a few turns and make sure all marks still line up perfectly.if not ,make necessary correction at the claw bolts on th coupling
