POSITIVE OR NEGATIVE GROUND FOR 1954 FMD
JOHN
06-08-2003 08:31:20
DOES THE 1954 FMD WITH SERIAL#1288922 HAVE A POSITIVE OR NEGATIVE GROUND. ALSO HOW WOULD YOU HOOK UP 2 12 VOLT BATTERIES, WHAT POWER FOR EACH BATTERY.
THANKS,
JOHN
Ron
06-12-2003 05:43:32
 Re: POSITIVE OR NEGATIVE GROUND FOR 1954 FMD in reply to JOHN, 06-08-2003 08:31:20
when two batterys are run in parallel, positive is linked to positive and negative to negative- this gives you 12volts with more capacity for cranking amps
when two batterys are run in series, positive is linked to negative between the two batterys- if they are 6v batterys you get 12volts- if they are 12v then you get 24v
Options
1. buy two 6v and run them in series
2. buy one large 12v
3. buy two 12v and run them parallel
tony
09-27-2003 04:16:36
 Re: Re: POSITIVE OR NEGATIVE GROUND FOR 1954 FMD in reply to Ron, 06-12-2003 05:43:32
Never run batteries in parallel!! They will never be at the same voltage. In the best case the one will kill the other, in the worst case, one will explode and kill you.
ray
06-13-2003 07:23:55
ron i was going to tell him the same thing but,i wanted to keep it simple...and affordable.thanks.
ray
06-10-2003 09:11:09
john,fm,fpm,fsm,postive ground,instead of two batteries,i would use one big battery,800-1000 cca,i only have one in my super major and it works fine,,and cheaper than two...hope this helps..
