Low reving Dexta
Mike
06-17-2003 13:37:13
I have a 63 Dexta that over a period of time seems to have dropped rpm. The tach doesn't work,
but if max throttle equals max rpm, then my max rpm is equal to 1/4 throttle. It has the pneumatic
fuel injector. Any clues?????
Tristan
06-23-2003 14:50:05
 Re: Low reving Dexta in reply to Mike, 06-17-2003 13:37:13
If this is any help at all you can alter the idling speeds by a screw on the RH side of engine block on throttle connections.
Good luck
Kruisin
06-23-2003 18:56:02
 Re: Re: Low reving Dexta in reply to Tristan, 06-23-2003 14:50:05
Mike,
Have you checked the air cleaner and air intake tube. It's worth a try.
