Fordson Super Major external Hydraulic valve
Rob C
07-13-2003 04:07:48
I am in the process of fitting a front end loader to my FSM. It is fitted with control levers to operate some external gear, possibly a post rammer. My problem is that I have no oil flow out of the external port on the push pull valve situated under the seat. The 3 point hydraulics work fine, so I assume I have a stuck valve some where. The push pull valve has not been used for some years.
Any suggestions on how to pull this valve unit apart and any tricks or hints, or even a diagram would be appreciated.
Cheers
Rob
Paul Barnes
07-13-2003 15:20:43
 Re: Fordson Super Major external Hydraulic valve in reply to Rob C, 07-13-2003 04:07:48
Have you tried putting the power lift arms down a little then pull out the push pull valve and then get oil to flow by pulling the power lift lever up.
ray
07-15-2003 07:06:35
 Re: Re: Fordson Super Major external Hydraulic val in reply to Paul Barnes, 07-13-2003 15:20:43
rob,have you checked to see that the remotes were put into gear,theres a little shifter under the seat on the right side of trans,that one works the remotes..my super major also has factory remotes..make sure main pump is in gear..
