Fordson Tractors Discussion Forum
Water in oil?
Garry
08-06-2003 06:48:11
The Super Major I recently purchased seems to have water in the oil and there is a miss in the engine at times. this is a diesel 5000. Is the problem the head gasket or is it more? I was told when I purchased it that it needed a head gasket, so this is not a surprise, but want to know exactly what I will need to repair. Also will it hurt to run the tractor some till I have a chance to fix it.
ray
08-07-2003 08:39:35
 Re: Water in oil? in reply to Garry, 08-06-2003 06:48:11
garry,i personaly would not run the tractor,the miss sounds to like a cylinder is filling with water and cant fire,the head gasket is not a big job,i did mine 9 years ago and its still holding together,not an expensive job.do it and save your engine.any new holland dealer will probably have it in stock.
ron algiere
08-10-2003 17:46:50
 Re: Re: Water in oil? in reply to ray, 08-07-2003 08:39:35
I agree with Ray, sounds like a head gasket. Don't run it until you fix it. Water in the cylinders can cause more damage than you can imagine.
