Fordson Tractors Discussion Forum
Serial number
ian
09-04-2003 08:42:29
does anyone know where to find the serial number on a fordson major diesil engine. Cause i wanna buy this:
Basic Engine Overhaul Kit- Diesel - Major Diesel with 220 CID 4 cylinder diesel engine .Engine s/n 1591022 & up Sleeves have large OD. flange 4.706” .(1.375 wrist pins).Kit includes sleeve & piston set, full gasket set, Rod & Main Bearings, and pin bushings. Specify Rod & Main bearing size: Standard, .010, .020 or .030(Regular price $809.97, your cost $736.34) (Part No: FMDK3)
but 1st i need to know if the serial is right :P
G.W.
09-09-2003 19:06:44
 Re: Serial number in reply to ian, 09-04-2003 08:42:29
According to my manual, the serial number is located on a pad at the front right hand side of the engine cylinder block. The engine serial number you stated (1591022) indicated that the tractor was built in March or April 1961.
Ian
09-17-2003 11:51:53
 Re: Re: Serial number in reply to G.W., 09-09-2003 19:06:44
I actually found the serial after doing some cleaning on a small plate, on the wall between teh battery and the engine, towards the top :]
Ian
09-10-2003 09:29:31
thanks a lot i'll have a look for it :]
