Fordson Tractors Discussion Forum
Simms injection pump squeaking
Lars
09-18-2003 17:18:40
I have an older Ford Dexta with the Simms pump and pnuematic governor. It recently started "cherping" at low RPM. If I hold the manual fuel pump lever in the up position, the noise fades, or goes away all together. I had cleaned the gauze filter at the last oil change, but notice that it was DRY. Is this normal, and what would be causing the noise?
