Fordson Tractors Discussion Forum
E27N Perkins P6 rebuild information required
Gavin Stewart
09-19-2003 05:14:07
Does anybody have any information on fitting alternative parts from other engines to rebuild the P6 engine. Ive heard you can use 3-144 and 3-152 parts.
clifford c benjamin
09-22-2003 18:01:47
 Re: E27N Perkins P6 rebuild information required in reply to Gavin Stewart, 09-19-2003 05:14:07
contact phill thain p.t engines 1 207 324 1019.he maybe to help you.
richard
09-20-2003 17:10:25
rebuilt one of these about 18 months ago got the parts from local perkins dealer,took a little while to arrive and very expensive.
Gavin
09-21-2003 02:57:37
 Re: Re: E27N Perkins P6 rebuild information requir in reply to richard, 09-20-2003 17:10:25
Thanks Richard,
What country are you from?
Im in Australia, and parts here are available but hard to find.
richard
09-22-2003 16:14:35
 Re: Re: Re: E27N Perkins P6 rebuild information re in reply to Gavin, 09-21-2003 02:57:37
I am from just outside Buxton,Derbyshire,England.Parts her are also difficult to come by but with a good storeman at your local Perkins agent you should get your parts.Check the origin of your engine,it may well be Austrailian built.The country code for Austrailia is 'C' so your engine may have a number like P= 6.305 family. A= P.6 5678943= Parts list number. C=Austailia (U= U.K.) 654321 = serial number. The last letter is the year code. It may well be worth sending an E-Mail to perkins for asistance,I have their adress here if you need it come back to me Hope this helps Richard
Gavin
09-23-2003 02:21:11
 Re: Re: Re: Re: E27N Perkins P6 rebuild informatio in reply to richard, 09-22-2003 16:14:35
Richard,
Thanks for your help again.
I have been able to track down a Perkins wrecker this end. I am going to take my old parts to him, and see if we can mix and match any parts from other Perkins engines. He said that the good thing about Perkins, is they used common parts throughout their range of different sized engines, and most are interchangable.
