Fordson Tractors Discussion Forum
Transmission Oil?
Jim Senger
09-22-2003 09:02:59
Hi Folks, Where do I check and fill the transmission on a 1957 FMD? I have the I&T book and it shows me how to take it apart, but not were to check and fill. What weight oil does it take? Can I use THD (Transmission/Hydraulic/Differential) oil in it? Any help would make my Fordson happy! Thanks, Jim S.
jdehoog
09-22-2003 15:36:31
 Re: Transmission Oil? in reply to Jim Senger, 09-22-2003 09:02:59
I put Universal tractor fluid in mine (THD) but I am a newbie to this tractor and hope it was the right thing to do.(Cold in Canada)
jdehoog
09-22-2003 15:32:53
There is a big cap in the left side of the transmission(just in front of the foot rest)You remove the cap and eyeball the level.The dip stick near there is for the rear end.
Jim Senger
09-22-2003 17:46:45
 Re: Re: Transmission Oil? in reply to jdehoog, 09-22-2003 15:32:53
Thanks, But could you pass on how high the level should be (by the eye,of course)? I live in Ontario, Canada.
Thanks, Jim S.
jdehoog
09-23-2003 18:54:13
 Re: Re: Re: Transmission Oil? in reply to Jim Senger, 09-22-2003 17:46:45
It is marked "High" and "Low".bring level up to "high".(It won't be too high at this mark)
Jim Senger
09-24-2003 03:27:53
 Re: Re: Re: Re: Transmission Oil? in reply to jdehoog, 09-23-2003 18:54:13
Thanks JD, It was empty, I had less then 3 ltrs in it. I drained it then topped it off (it sounds better now). The New Holland dealer down here has an old fella that works at the parts counter, grew up with FMDs and says TDH oil works well in transmission, final drive system and hydralics.
Thanks for your help, Cheers, Jim S.
