Fordson Tractors Discussion Forum
Serial 151129 for 1960 FORDSON Major diesel?
sean
10-17-2003 09:12:52
Is this correct? It has a four cylinder diesel engine with a front end loader and a backhoe.
Sean
Ian
10-17-2003 15:33:33
 Re: Serial 151129 for 1960 FORDSON Major diesel? in reply to sean, 10-17-2003 09:12:52
apparantly it will be under number 1 fuel injector .. or where i found mine was
on the firewall (whatever its called) between the battery and engine on a small plate at the top.
Bob D UK
10-20-2003 14:04:10
 Re: Re: Serial 151129 for 1960 FORDSON Major diese in reply to Ian, 10-17-2003 15:33:33
Your serial number should have seven digits, not six. If you have found the first six, you have a 1959 Power Major. Check out the number again, then refer to the 'Serial Numbers' link at the left of this page.
