Fordson Tractors Discussion Forum
Frodson Major ID
J Hardy
12-09-2003 16:07:45
I have just acquired a Fordson Major Diesel. I have no idea of it's date or model. The engine number is D132331. It looks about the 60's and has a no 3 point linkage fitted. There is a flat plate under the seat where I have seen, on othe models,the controls for the 3 point system. There is a large back hoe on it. The hydrolic pump is direct driven off the front of the crankshaft. Can anyone help identify it please.
Cheers
NC Bill
12-10-2003 11:42:02
 Re: Frodson Major ID in reply to J Hardy, 12-09-2003 16:07:45
Hye J You well need to find the Serial #. Most are located on a pad at the front right hand side of the engine cylinder block. That is ware i fund my serial# it IS 08D-954342-C it was a 3/1964. On early tractors the # is stamped on the flange of the flywheel housing near the starter mounting. Good luck. Bill
J Hardy
12-10-2003 12:29:20
 Re: Re: Frodson Major ID in reply to NC Bill, 12-10-2003 11:42:02
Thanks Bill, I have just looked on the Cylinder block and the pad is there but has no numbers. After scrapeing off the paint and drit on the Flywheel housing I found a number. It is 1323314. I hope this means something to someone.
Cheers
NC Bill
12-10-2003 13:09:11
 Re: Re: Re: Frodson Major ID in reply to J Hardy, 12-10-2003 12:29:20
YES J It is a 1/1955 from#1322525 to 1326303. That is the New Major Series it was made from 1953 to 1958. it is a good one hope you like it. Bill
J Hardy
12-10-2003 15:41:31
 Re: Re: Re: Re: Frodson Major ID in reply to NC Bill, 12-10-2003 13:09:11
Thank you so much for your help. Yes I do like it when I can get it to run. It has a very suspect Starter Motor. I will get it recond and all will be well.
Thanks
