Fordson Tractors Discussion Forum
FSM 1964 Wish Bone
Mack
12-14-2003 01:17:45
Hi People
I"ve been given a 1964 FSM.....has water in the oil....have checked the head gasket ...it's ok....so I'm going to take the sump off ...Is there a easy way to get the wish bone off !!!!
Any advise welcome as I'm not what you would call too " mechanical"
Thanks heaps.....have a wicked day
Mack
Steven B
12-14-2003 14:12:48
 Re: FSM 1964 Wish Bone in reply to Mack, 12-14-2003 01:17:45
I wouldnt worry about the wish bone. You need to strip that engine and replace the sleeves. They will be leaking around the lower O ring.
Best of Luck
Steven
Bill S.
12-18-2003 19:16:42
 Re: Re: FSM 1964 Wish Bone in reply to Steven B, 12-14-2003 14:12:48
Mack, Yes you must remove the front axle stabilizer to drop the oil pan. There will probably be enough oil on the cotter and pin beneath the pan to extract it with reasonable ease. The two bolts thru the front beam may be dry and tight. Patience, penetrant, good wrenches, and as last resort heat, they will come. Knock on wood! Indeed, you have a great deal more ahead but that should answer your question. Bill S.
