Fordson Tractors Discussion Forum
Hey Burrhead!!
capp
01-01-2004 16:44:59
My imput shaft seals on the transmission are leaking again. I was wondering how much slop the shaft that goes into the pilot bearing is supposed to have. Also I don't have a 100 hours on these seals, what to you reckon happened? The shaft will go up and down a quarter of an inch either way. Hope you all had a good Christmas!!
Take care.
Capp
Burrhead
01-02-2004 17:38:38
 Re: Hey Burrhead!! in reply to capp, 01-01-2004 16:44:59
Hello Capp. Hope Santa was good to you and yours.
I'm thinking out loud here on this so don't let a yuppie git after me.
It sounds like the inner pilot shaft needle bearing is bad.
There are needle bearings inside the shaft as well as the roller bearing on the shaft. The inner needle bearings go bad from rust and gald sometimes.
If it's the roller bearing sometimes you can shim the front cover against the bearing and take the slop out.
capp
01-03-2004 16:50:52
 Re: Re: Hey Burrhead!! in reply to Burrhead, 01-02-2004 17:38:38
Thanks Burrhead I will have a look at this Monday. You all have a good one. Capp
