Fordson Tractors Discussion Forum
dexta primer
Billy ar
01-06-2004 07:51:17
A friend of mine's primer was leaking and he removed it. He teed the line from the intake into the fuel line, no cutoff no check nothing. Little hard to start Any input would be helpful thanks.Billy ar
Billy ar
01-08-2004 12:42:40
 Re: dexta primer in reply to Billy ar, 01-06-2004 07:51:17
thank,s for the info
Tractorfix
01-06-2004 18:40:33
At best, it will overfuel, wash the bores and smoke the rings and bottom end. At worst, it will hydraulic lock and blow itself to pieces.
mwo
01-06-2004 07:58:13
I took of the primer also because it was leaking and tied in a rubber fuel line into a hand primer bubble (like you use on outboard motors) Put a cutoff switch on the other side. It worked great.
PAUL(UK)
01-10-2004 12:25:20
 Re: Re: dexta primer in reply to mwo, 01-06-2004 07:58:13
I removed a leaking primer from my dexta fitted a tee inits place fitted a new heater plug soenoid type as found on MF35X only lets fuel in when heater button is pressed,works fine has done every day for the last 10 years
