Fordson Tractors Discussion Forum
Major injection timing
Gary U.K.
01-11-2004 10:59:21
I have a FDM witch won't start from cold. It turns over fast enough but won't run without a tow, or the dreaded "easy start". Once running it seams fine apart from a hesitation on full revs, and will start o.k when warm.
Could this be the injection timing???
If so can anyone tell me what the timing should be and how to set it!
Or is there another reason for this problem?
p.s. it is sporting a brand new lift pump;
Thanks for any help in advance.
Randy
03-21-2004 12:43:28
 Re: Major injection timing in reply to Gary U.K., 01-11-2004 10:59:21
Aim the flame from a propane torch down the intake while cranking. It gives you enough heat to get it started.
Randy
