Fordson Tractors Discussion Forum
Dexta with pressure in crankcase
BRIAN
01-14-2004 19:05:15
IS THERE ANY HOPE OF A BLOWED HEAD GASKET OR IS IT BUSTED PISTON.
tony
01-15-2004 03:47:16
 Re: Dexta with pressure in crankcase in reply to BRIAN, 01-14-2004 19:05:15
Brian, I had the same thing happen to my dexta. It was so bad that it was pushing oil out of the diptstick. I also had fine droplets in the exhaust. The tractor was hard to start but once I got it going it ran. But it was harder and harder to start each day. This October I had enough and decided to rebuild her. After I got in there, I found that I had a cracked head and the pistons were so worn that the just fell out when I disconnected them from the crank. I’m amazed that it ran at all. I think you’ve got a nice project on your hands. Good time of year for it (unless you’re in Australia). I still don’t have mine girl running yet, but I’m getting close. I took everything apart from the transmission forward, cleaned it, painted it, and replaced all the rusted bolts and it’s almost back together. Should fire it up maybe next weekend.
