Fordson Tractors Discussion Forum
INTALLING A FRONT PUMP ON A FORDSON
RON DOW
02-07-2004 22:13:26
I HAVE A FORDSON TRACTOR I THINK IT IS A 58 OR 59. I HAVE A LOADER I WANT TO MOUNT ON IT I WANT TO KNOW IF IT IS POSIBLE TO SWICH THE FRONT PULLEY TO ONE THAT CAN HOOK UP TO A FRONT PUMP? ALSO HOW DO YOU REMOVE THE FRONT BOLT ON THE CRANK SHAFT? IS THERE ANY WHERE TA BUY PARTS I NEED THE SEAL THAT GO IN THE TIMING COVER.
Ron A
02-08-2004 02:06:32
 Re: INTALLING A FRONT PUMP ON A FORDSON in reply to RON DOW, 02-07-2004 22:13:26
There's no need to remove anything, the pump gets mounted on to the chasis and is driven off of a coupler that bolts to the front pulley bolts.
RON DOW
02-20-2004 23:15:37
 Re: Re: INTALLING A FRONT PUMP ON A FORDSON in reply to Ron A, 02-08-2004 02:06:32
MY FRONT PULLEY HAS NO BOLTS OTHER THAN THE ONE IN THE MIDDLE FOR STARTING WITH A HAND CRANK. THE PULLEY IS NOTHING LIKE THE ONE ON MY 861 FORD.
THANKS,
RON DOW
