Fordson Tractors Discussion Forum
inj. pump timing line
David
02-22-2004 17:09:02
hi all,
i have a 58/59 fordson dexta. after putting on a newly rebuilt inj pump, i checked the timing. with the spill mark lined up, and looking through inj pump gear window, i see three lines. two lighter lines- one above and one below a third darker line marked "C". the housing mark is lined up exactly with the lowest light mark. figuring the "C" line is where i need to be, i opened the front cover loostened the 3 bolts to adjust. Well, when i attempted to advance to the "C" line i hit a stop before i could get to it. i'm about 3/16 of an inch away. is this ok/close enough/, should i investigate further? i moved the gear plate back and forth to see how much adjustment i would have either way and its not much more than about an half inch either way. should this be ok?
thanks to everyone, david
Scooter
03-13-2004 05:19:08
 Re: inj. pump timing line in reply to David, 02-22-2004 17:09:02
third party image
go to next follow up
Scooter
03-13-2004 05:22:23
 Re: Re: inj. pump timing line in reply to Scooter, 03-13-2004 05:19:08
third party image
and the next one
Scooter
03-13-2004 05:27:44
 Re: Re: Re: inj. pump timing line in reply to Scooter, 03-13-2004 05:22:23
third party image
I suppose you know one way or the other now. This might help someone :)
Tom in Cherrylog
03-30-2004 19:59:38
 Re: Re: Re: Re: inj. pump timing line in reply to Scooter, 03-13-2004 05:27:44
Couldn't open the image files. My Dexta runs rich then dies as it warms up. Suggestions?
