Fordson Major Engine Rebuild Kit
Steven B
05-30-1999 11:48:30
I'm getting ready to rebuild my Major and I'm wondering how much I'm looking at spending on a rebuild kit and if any vendors on this site offer such a thing? Also, I may need a new crank as well. Are they hard to come by? Thanks in advance for your response,
Steve
Nellie
05-31-1999 04:50:33
 Re: Fordson Major Engine Rebuild Kit in reply to Steven B, 05-30-1999 11:48:30
This site has kits, I think. I got mine at Central Tractor they are very competitive on pricing. I got a crank for $350 that was reground from my local tractor salvage yard. Besure to check crank end play. The trust bearings at no. 4 main tend to fall out down into the oil pan. It will run fine for about 6-12 mo. than you will find you machined away part of the block. Now that expensive. Good luck.
Don
05-30-1999 15:11:22
Steven: Plan on at least 850.00 to 900.00 for a FMD rebuild kit. A new crank is most likely out of the question but a reground crank will run anywhere from 400.00 to 500.00 dollars. Rebuilt block assemblies will run you around 1600.00.
I have found over the past 5 years I can count on
around 2700.00 in an FMD engine overhaul and it
is sometimes necessary to have the injection pump
rebuilt: add another 700 to 1100 to the tab.
Not a cheap hobby, keeping our little Blue diesels going! Walt's Tractor Parts, a sponsor of this site should carry FMD rebuild kits.
