Fordson Tractors Discussion Forum
What size battery
Greg C
03-01-2004 16:47:16
What size battery do I need for my 59 Dexta...550 cranking amps doesn't seem to be doing the job.
Burrhead
03-07-2004 21:22:46
 Re: What size battery in reply to Greg C, 03-01-2004 16:47:16
That 550 amp will crank it okay in 90 degree weather but you need a 1000-1100CCA.
If there is a Freightliner dealer near you their 1050amps are on sale nationally for $50. I have always used a 1000 to 1150CCA in my Super Dexta and it cranks down to 20-30 degrees without the primer or glow plug. The bigger batteries will fit your space and will spin the dexta engine like a window fan.
Greg C
03-11-2004 18:21:10
 Re: Re: What size battery in reply to Burrhead, 03-07-2004 21:22:46
You are right about it cranking it in 90 degree weather...cranked easy the other day at 70 but anything lower it won't. Am going to get the larger battery before I go changing anything else.
Thanks
Dave
03-02-2004 03:29:31
What shape is your starter in? My Super Major was turning over slowly, a new battery didn't help at all, but a new starter made a huge difference.
