Fordson Tractors Discussion Forum
Fordson Major Diesel
Mike
03-02-2004 16:56:03
Hi
I have a fordson major diesel w/ front loader & backhoe .I have no idea what year it is? Do you know where the vin #s are on the engine. I found a Vin plate on the firewall but it's unreadable.
Thanks
Mike
wolfy
03-05-2004 17:57:02
 Re: Fordson Major Diesel in reply to Mike , 03-02-2004 16:56:03
Had a Major a few years back. If I remember correctly, the serial number was found like on the firewall behind & above engine near battery box.
Mike
03-05-2004 19:03:32
 Re: Re: Fordson Major Diesel in reply to wolfy, 03-05-2004 17:57:02
I found that plate but the numbers are not readably.. Is there another way to tell the year?
Link
Mike
Scooter
03-19-2004 03:30:12
 Re: Re: Re: Fordson Major Diesel in reply to Mike , 03-05-2004 19:03:32
The stamping on my FPM equates to it being built Jan 1960, but that plate you describe says April 1960. So I guess that was how long it took between the tractor being made, to when it arrived in Australia.
Ron A
03-05-2004 04:41:25
look on the front right side of the block, just under the seam of the head there will be a flat machined section about 1/2 inch in hieght and 2 inches wide the numbers should be stamped there
Mike
03-05-2004 15:37:54
 Re: Re: Fordson Major Diesel in reply to Ron A, 03-05-2004 04:41:25
Ron
The machined pad was never stamped no numbers ? I replaced a broken cast crankshaft a few years ago with a NEW Steel crank! We just matched the new one to the old . But the guy i got the crankshaft from said that ford/fordson was replacing the cast cranks with new steel units back when the tractors were new! Mine just took longer to brake? And this tractor has a Heavy Duty Hoe unit & Loader but looks factoryish? I posted a few pictures of the Major on my web page. Link below..
Http://community.webshots/com/user/map351
Mike
Majorman
03-06-2004 09:52:30
 Re: Re: Re: Fordson Major Diesel in reply to Mike , 03-05-2004 15:37:54
On a 1953 Major the serial number is stamped on the flange behind the starter motor.
The cast crank was rather weak and was replaced early in the tractors life with a steel version. I still have a cast version in my tractor and had it ground to .010" a couple of years ago when a bearing failed. The steel cranks and most of the parts are still available.
Mike pierro
11-11-2004 07:28:07
 Re: Re: Re: Re: Fordson Major Diesel in reply to Majorman, 03-06-2004 09:52:30
Does anyone have a part# for a oil filter for my Fordson Major (Stewart diesel) My local parts store can't seam to find any info on the old filter.
Leonard
10-20-2004 11:49:37
I have a Fordson Majors diesel tractor with a backhoe the tractor is not running.I will not be rebuilding the engine and wanted to see the tractor reused by someone contact me at 734 216-4507.
Mike
03-17-2004 05:36:36
What's the trick to stop the coolant from leaking around the throttle shaft that passes through the block ? Is there a packing seal ?
I looked for the vin by & behind the starter , can't see any #s guess i have to pull the starter ?
Mike/Map
larry
03-03-2004 14:44:02
I have a 1593 Fordson Major Diesel I ma trying to find out what it worth.Fordson was maid in Canida .I think it part of Fergson of Massey Fergson.
SAm in NS
03-06-2004 03:58:32
 Re: Re: Fordson Major Diesel in reply to larry, 03-03-2004 14:44:02
Fordsons were built in the UK and they were Fords tractor and had nothing to do with Massey Ferguson or Ferguson. Hope this helps. SAm in NS
