Fordson Tractors Discussion Forum
Need starter for 58 Dexta diesel.
Bernie Guettler
03-04-2004 11:06:14
I am in need of a starter for a 1958 Dexta. The starter is a Lucus M456. I had this one repaired last year but now it drains the battery if the hot wire is connected. When I went out to use it after setting most of the winter the battery was dead. I charged it and when I connected the battery it drew a good arc. Took starter off and connected a battery up to it with jumper cables. When doing so it drew a big arc. Thanks for any help.
tony
03-04-2004 12:38:36
 Re: Need starter for 58 Dexta diesel. in reply to Bernie Guettler, 03-04-2004 11:06:14
bernie, that doesn't right. Power for the starter goes through the solenoid and if the solenoid is not powered up, then no voltage should be on the starter. It's an open circuit. I think you need to elsewhere for your fault.
Bernie
03-04-2004 16:01:17
 Re: Re: Need starter for 58 Dexta diesel. in reply to tony, 03-04-2004 12:38:36
Tony, you are correct. The problem was a bad solenoid. I will replace it tomorrow. Thanks
Bernie
