Fordson Tractors Discussion Forum
Gas Dexta heating problem
Bill Johnston
03-10-2004 18:56:02
I have a gas Dexta with an over heating problem. I had the radiator rebuilt, same problem. New water pump, rebuilt carb, new oil pump, new pistons and sleeves, new crank bearings, and still overheating.Also, as the temperature goes up, the oil pressure drops. I didn't grind the crank. Does anybody have any ideas?
tractorfix
03-13-2004 04:04:24
 Re: Gas Dexta heating problem in reply to Bill Johnston, 03-10-2004 18:56:02
I wpuld have to say it is lean, or the timing is retarded. Oil pressure is inversely proportional to temperature. The general rule of thumb is 10psi per 1000rpm hot. So basically, if you have about 20 at full speed, you're OK. Even 15 would get you by.
Keep the blue side up!
Kevin
