Super Dexta warning lamps
Dave Wightman
12-20-1999 09:27:51
I have a Super Dexta with no warning lamps fitted. I think there should be lamps in the two holes in the plate under the steering wheel (next to the temperature guage), and two in the panel next to the hour meter.
Can anyone tell me what the lamps are for? (I have a workshop manual, but this does not have a wiring diagram for the Super).
Thanks,
Dave W, UK
Burrhead
12-20-1999 15:23:05
 Re: Super Dexta warning lamps in reply to Dave Wightman, 12-20-1999 09:27:51
Mine only has 1 light on each side of the steering. The left one is oil pressure and the right is generater. I'll look in my book to see if there is a wiring schematic.
Oscar
12-28-1999 06:27:50
 Re: Re: Super Dexta warning lamps in reply to Burrhead, 12-20-1999 15:23:05
I could be wrong, but as far as I know the LEFT one should be the generator, and the RIGHT one should be the oil pressure. There's definitely a wiring schematic in both the instruction book and the maintenance manual. The oil pressure indicator light is essential, without it you can't tell if something's wrong. That could cost you your engine.
Burrhead
12-28-1999 17:14:10
 Re: Re: Re: Super Dexta warning lamps in reply to Oscar, 12-28-1999 06:27:50
Your right I went back and read it again. I had written it backwards. Musta fergot which hand I have the x on.
