Fordson Tractors Discussion Forum
Major gas needs choke to run smooth...What's wrong
Miles
03-27-2004 12:06:15
Plugs are sooty black and need to be cleaned every 6 hours. Carb internals appear clean and functioning properly.
Also, is there any maintenance required to the governor on these tractors. Its doesn't seem like the throttle is engaged properly under load.
Thanks
ray
04-07-2004 08:21:05
 Re: Major gas needs choke to run smooth...What's w in reply to Miles, 03-27-2004 12:06:15
hi miles,is there not a fuel air mixture screw on that carb..may be vaccum advance is not working,too much fuel going in,reset float so that it will shut fuel off when sitting level with top of bowl,try that or you may need a kit,theres a fellow in delhi ont.that sells zenith kits...
Miles
04-09-2004 08:40:54
 Re: Re: Major gas needs choke to run smooth...What in reply to ray, 04-07-2004 08:21:05
Hi Ray,
What is the dealer's contact info in Delhi...I could use a couple of carb kits.
Thanks
