Fordson Tractors Discussion Forum
SUPER DEXTA PTO
BILL
04-06-2004 18:07:28
PTO WILL NOT ENGAGE ---WAS WORKING FINE LAST TIME USED HELP!!
sibby(Aus)
05-02-2004 02:51:02
 Re: SUPER DEXTA PTO in reply to BILL, 04-06-2004 18:07:28
Bill, if it was working fine when you last used it, i would say that your clutch plate could be stuck, run engine to normal operating temp and try and unstick it under load ,cheers matey!!!
Paul
04-09-2004 17:02:15
Wont engage??? Is it grinding when you try or does the lever go where it should do but the pto doesnt turn? If it's the first option, your dual clutch needs adjustment or replacement.
