Fordson Tractors Discussion Forum
ID dexta
bobby
04-13-2004 18:41:56
The serial# is 957E 7005 can anyone tell me what
year it is and if it is a dexta. It is a 3 cylinder desil and a 3 speed with a HI and LO gear stick
J.Ireland
04-23-2004 02:15:50
 Re: ID dexta in reply to bobby, 04-13-2004 18:41:56
My dexta recently restored is 957E 22899.When I tried to date it the build time seemed to be late 1958 or early 1959 I recall only vaguely that about 15,000 were built over that period. Your machine would probably be late 1957.
Paul
04-18-2004 02:27:35
The number you have is a casting number. The serial number is stamped onto the flange between the clutch bellhousing and the engine on the left handside.It runs vertically. You may have to clean years of paint & grime off to find it, but it's there.
bobby
04-24-2004 09:15:31
 Re: Re: ID dexta in reply to Paul, 04-18-2004 02:27:35
i found the serial number it is 957E93285 I would like to know the year it was made and what size of tractor it is compareto in horse power
is it the same as the 600 or 800
GEORGE GLOVER
04-14-2004 09:00:59
I too am working on an old Ford 2000 (DEXTA) Please advise where on the tractor did you locate the serial number?
bobby
04-14-2004 14:55:11
 Re: Re: ID dexta in reply to GEORGE GLOVER, 04-14-2004 09:00:59
I found the serial # on the trans on the side that the starter is on.
