Fordson Tractors Discussion Forum
successful rebuild???
J.Ireland
04-18-2004 14:53:26
1959 dexta restoration now complete. Thanks to Paul,Burrhead, Stefan, Wayne and others for help often unknowingly given by information placed on fordson website. Any final advice about running in the rebuilt engine?
Burrhead
04-18-2004 19:47:59
 Re: successful rebuild??? in reply to J.Ireland, 04-18-2004 14:53:26
Only thing I do is crank and let get up to operating temp as I re+re+re+check for oil or water leaks. Then I keep the load moderate for the 1st week or so. Outside of that I don't baby it much once the rings get seated.
One thing I always do is keep a close check on the temp and oil pressure.
Burrhead
04-18-2004 19:48:54
 Re: Re: successful rebuild??? in reply to Burrhead, 04-18-2004 19:47:59
I forgot to say congrads on the job and hope you have many hours of Dexta joy.
David
04-19-2004 19:30:13
 Re: Re: Re: successful rebuild??? in reply to Burrhead, 04-18-2004 19:48:54
Burrhead ,
would you consider shredding 2-3 foot high grass, "moderate" workload?
thanks, david
Burrhead
04-19-2004 19:51:51
 Re: Re: Re: Re: successful rebuild??? in reply to David, 04-19-2004 19:30:13
with a 5' shredder in average grass yessir I consider it moderate,
with a 6' shredder or in very heavy grass I would call fairly hard work.
If you're gonna be shredding as you break in the rebuild I would make extra checks to the engine temp, and I would run the engine in a hard pull for a few minutes (10-15) and then slow down and take it easy (10-15) minutes per cycle.
That hard-easy cycle works best for me on any breakin.
