You folks are probly thru with your project but here's what I do. I don't use regular gasket sealer. I clean the head, block, and hang my new head gasket from a wire so I can get to both sides. I take regular aluminum paint and paint the head gasket, then paint the block and head mating surfaces. Just as the paint starts to get tacky to the touch I put one more coat on the head gasket. Now when it starts to get tacky to the touch again I put the gasket on and install the head. Torque to normal pressure and let set over night. Next morning I rerun the head bolt torque and fire it up. Don't worry about what little paint gets into the water and oil galleys just be sure and don't over do it into them. The aluminum paint does better than sealers about taking the imperfections out of the mating surfaces and the sleeve. It works good on sleeve o-rings too, but unless the block is pitted from corrosion I just clean the block and install the o-rings with a little chassis grease on the o-rings.
