Fordson Tractors Discussion Forum
Fordson Major Diesel Wiring Diagram
Tom T
05-12-2004 15:55:12
Does anyone know where a fellow may find a wiring diagram for a 1954 Major diesel? For the life of me I can not locate the regulator on the tractor, unless it has been removed. The charging circuit does not work.
Am also looking for a fuel shut off cable.
Mike M
05-14-2004 06:53:01
 Re: Fordson Major Diesel Wiring Diagram in reply to Tom T, 05-12-2004 15:55:12
Tom...I have a '56 FMD and the regulator was behind the instrument dash panel. I also had a hard time finding it. The shut off cable was given to me by a neighbor, but was a universal type cable & housing he said was used on trucks.
Hope this info helps.
Jay
05-14-2004 06:02:44
Hi,Tom I see you have gotten information you need. I have a 54 major also and any parts you may need in future that you cannot find go to www.agriline product.com and you can get anything you need for the major. Jay N
Jerry G
05-13-2004 04:52:35
Tom, my '55 has the original generator and the regulator is up by the air cleaner on the back side of the battery box. I'm not sure if this is the original location as it is an aftermarket unit. If your tractor has been converted to a 12v alternator system, then yours would be electronic and incorporated into it. If you post your email address I'll send you a .jpg of the wiring diagram. It may be something as simple as polorizing the generator. If you need more info, just ask. Jerry
Fordson Major Diesel wiri
05-13-2004 06:07:49
 Re: Re: Fordson Major Diesel Wiring Diagram in reply to Jerry G, 05-13-2004 04:52:35
This tractor is a 12 volt system with a Lucas generator. The generator has two posts, these two wires I traced in the harness up to the key and guages. Any help would be greatly appreciated.
Thanks,
Tom T
Paul Dawson
01-09-2006 11:38:35
 Re: Re: Re: Fordson Major Diesel Wiring Diagram in reply to Fordson Major Diesel wiri, 05-13-2004 06:07:49
Hi Guys
Thanks for posting a FMD wiring diagram. i have almost completed restoring a 1957 FMD but the wiring loom is shot, i have repaired the control switch, but i am lost on wiring in the Ammeter. i cant quite understand the wiring of the ammeter in your posted drawing am i missing something?
Regards
Paul
Jerry G
05-13-2004 19:07:58
Here's the wiring diagram.
Bob
05-13-2004 21:46:02
 Re: Re: Re: Re: Fordson Major Diesel Wiring Diagra in reply to Jerry G, 05-13-2004 19:07:58
Hello Jerry, would you happen have or know where I could find a wiring diagram for a 1950 John Deere M? Thank you, Bob
Jerry G
05-14-2004 05:08:28
 Re: Re: Re: Re: Re: Fordson Major Diesel Wiring Di in reply to Bob, 05-13-2004 21:46:02
Bob, I don't have anything for John Deere Tractors. I'd do some searches on the web for John Deere Tractor groups and I'm sure the information is out there. There's plenty of folks out there ready to help. On the off-chance, you might try calling Faxon Auto Literature (800-458-2734) to see if they do a reproduction repair manual for your tractor. I got a repro Instruction Book from them for my '55 Fordson and it is top notch quality. Lots of luck, Jerry
Bob
05-14-2004 19:29:27
 Re: Re: Re: Re: Re: Re: Fordson Major Diesel Wirin in reply to Jerry G, 05-14-2004 05:08:28
Thanks Jerry for your reply and the information. Bob
Tom T
05-13-2004 20:27:19
Hi Jerry,
Thanks for the wiring diagram, I'm sure I can figure it out with this help.
Thanks again,
Tom T
