Fordson Tractors Discussion Forum
Fuel problems 62 standard dexta
HENRY JOYCE
05-17-2004 02:57:17
Hello,
Greetings from GALWAY, IRELAND My otherwise super reliable dexta has some type of fuel/pump airlock problem.
It will run all day at light work. Yesterday ,while mowing with a bush hog, it began to splutter when the engine came under pressure, either as a result of heavy grass or going up hill. The tractor looses power and dies. I got it going again by bleeding the injector pump. When the tractor comes under any pressure ,the same thing happens. I (partly)overcame the problem yesterday by leaving the bleed screw partially open It only died twice in an hour!
When the tractor starts missing i find it useful to prime the lift pump on the block. Interestingly, when the tractor is misfiring or idling there doesnt seem to be enough pressure in the injector pump to drive diesel out the bleed arpreture.
I have several theories that the experts may be able to advise me on:
1 DIRT in the tank or fuel lines ( however the fuel filter is new) Is there a filter to go into the tank?
2. PROBLEM WITH THE OUTPUT OF THE INJECTOR PUMP
3. dIAPHRAGM(S) IN THE INJECTOR PUMP PERISHED, WHEN THE TRACTOR IS UNDER PRESSURE, , CRACKS IN THE DIAPHRAHM EXPAND AND SUCK IN AIR CAUSING THE PROBLEM
4.All of the above
5. none of the above.
Please advise! Thanks
Henry
Majorman
05-17-2004 09:35:45
 Re: Fuel problems 62 standard dexta in reply to HENRY JOYCE, 05-17-2004 02:57:17
Henry,
I would suspect nothing more than a blocked tank filter. This is in the fuel tap and you have to drop the tap to clean it.
To prove it. Disconnect your line from the tap to the pump and see how fast the fuel flows. Should be pretty fast.
henry joyce
05-20-2004 07:56:26
 Re: Re: Fuel problems 62 standard dexta in reply to Majorman, 05-17-2004 09:35:45
thanks majorman
Ill try this at the weekend1 I ll let you know how i get on byee
henry
