Fordson Tractors Discussion Forum
Smith Hydraulics on E27N
John
05-29-2004 10:21:06
Can anybody help me? I recently restored an E27N and put on a Smith Hydraulic unit for the 3 pth. I tore it apart and cleaned everything up inside. Now when it operates it will go up regardless of the position of the lever - even in the down position the arms still go up. Could this possibly be a valve stuck? Any suggestions?
CalG
06-01-2004 05:59:03
 Re: Smith Hydraulics on E27N in reply to John, 05-29-2004 10:21:06
It would have to be a stuck valve!
The actuator shaft has a couple of cam lobes on it that push against spring loaded sliding valves.
It sounds like you have either a defective spring or a sticking valve.
You may need to "tear it apart and clean everything up inside" again. This time, look to the correct operation of all the moving parts.
Good luck
CalG
