Fordson Tractors Discussion Forum
hydraulic lift control-fordson dexta
J.Ireland
06-10-2004 15:31:16
After successful engine restoration fordson dexta tractor is running well- but no hydraulics. Lift control arm is stuck in lowest position. Apart from replenishing oil no work was done on hydraulics. Cover plate has since been removed and seals replaced but lift control arm still non operational. I can find no guidance in the fordson archives or specialist smaller websites.Anyone met this problem?
Paul
06-16-2004 01:26:41
 Re: hydraulic lift control-fordson dexta in reply to J.Ireland, 06-10-2004 15:31:16
Sounds like a stuck control valve. www.fordson-dexta.de is where you need to go.Page 14 under the heading mein / my Dexta. Should help you out.
P Lee
03-24-2005 18:20:55
 Re: Re: hydraulic lift control-fordson dexta in reply to Paul, 06-16-2004 01:26:41
Be sure the draft control lever on the right side under the seat is in the up position.
