Fordson Tractors Discussion Forum
ford major backhoe
derek
06-23-2004 21:30:15
just wondering if anyone could tell me where i could find hydraulic hoses or fittings (odd ones) on the loader and backhoe on a brittish made ford major backhoe. i'm unsure what year it is.
scott in pa
08-07-2004 18:03:29
 Re: ford major backhoe in reply to derek, 06-23-2004 21:30:15
derek,
who built the backhoe attachment? Ford or sherman are the two i have come across. I own a 61 supermajor with a ford loader and hoe. The factory fard hose fittings are available from ford/new holland but are about $35 each. I had a guy look at mine and he discovered that the valves and cylinders are double seated. They will accept standard sae fittings. I replace every hose except 2 on mine with the standard fittings and haven't had a problem in the 1 1/2yr since. If you want a picture of the new fitting email me and i'll send it to you. good luck
Carl Holmes
09-13-2004 12:36:33
 Re: ford major backhoe in reply to scott in pa, 08-07-2004 18:03:29
I have a 1962 SMD with backhoe.
I would like a picture of that fitting, because in minnesota I can't find anything at all. P.S. Any paperwork is appreciated.
CARL
Robert Starling
06-24-2004 07:41:53
Derek,
Most NAPA or more professional parts stores can make whatever size hose you need. Just take your old one to them and they will match the fittings and then custom make the hose there on the spot. Good luck, Robert
