Fordson Tractors Discussion Forum
GL-5 oil in Fordson
Kile
07-09-2004 16:51:44
I recently rebuilt a 24 Fordson and was having some difficulty finding the proper gear oil 600W for the trans and rearend. I was told that GL-5 used for HD truck rear ends would work out OK. Later I discovered that GL-5 has sulfur in it and it would harm the rear end mechanism in the Fordson. Is this legit or Bull. Should I take it out and replace it or just forget about it. Thanks for the assistance.
Joel Watkins
07-12-2004 18:22:49
 Re: GL-5 oil in Fordson in reply to Kile, 07-09-2004 16:51:44
All Gear lube except GL-1 has sulfer in it as a antiwear agent.Sulfer compounds form sacrificial materials, so wear occurs between the sulferized films instead of the gear teeth. The only problem using a lubricant containing sulfer is that is does not work well in a gear box containing copper. If this is an issue, use a GL-1 oil. (Motor Oil)
Don Young
07-13-2004 21:38:05
 Re: Re: GL-5 oil in Fordson in reply to Joel Watkins, 07-12-2004 18:22:49
I believe the old Fordsons used a brass worm wheel in the drive and that this makes oils containing sulfur unsuitable. I am not certain of this and hope someone else can tell you for sure.
