Fordson Tractors Discussion Forum
3 pt lift problem
Garry
07-13-2004 11:31:54
I have a Super Major with a lift problem. The lift will raise slowly without any weight on it but will not raise at all with weight. Once it is raised you can put weight on it and it will hold. I drained the oil, cleaned the filter, and put in new transmission oil. Prior to then it would not lift at all. What do I check next?
Johnny
07-25-2004 06:21:37
 Re: 3 pt lift problem in reply to Garry, 07-13-2004 11:31:54
Try replacing the valve assy. in the Hydraulic
power lift pump. It work for me.
