Fordson Tractors Discussion Forum
Engine swap
Gerry
07-25-2004 06:50:16
Could I put a 256 diesel engine out of a 5000 in a major 1959 or 60 diesel. Gerry
Roger.
07-25-2004 10:59:47
 Re: Engine swap in reply to Gerry, 07-25-2004 06:50:16
Going on the theory that if you throw enough money at it then yes you can but I guess for practical purposes I think not,the fitment of a six cylinder ford diesel is more common.
ANON
08-07-2004 15:34:38
 Re: Re: Engine swap in reply to Roger., 07-25-2004 10:59:47
What is the 6 cylinder that is common to put in? Looks like a bigger version of the four.
Roger Perry/Perry farming
08-08-2004 07:50:25
 Re: Re: Engine swap in reply to ANON, 08-07-2004 15:34:38
I have seen several with a Perkins but the most popular by far are Ford's, they are the truck engine,you will need to buy or make a conversion plate,extend the side rails and modify the front axel support struts,its common to see them turned around to the front,if the truck engine sump is steel you can cut it if you need to,aluminum is not so easy.
ANON
08-08-2004 13:20:07
 Re: Re: Engine swap in reply to Roger Perry/Perry farming, 08-08-2004 07:50:25
Just saw one that looks like it bolted right up to the trans without an adapter plate but he had homemade frame rails.
Gerry
07-26-2004 20:05:03
If you say the bolting patern is different, I am not gone get into it tanks for info. Gerry
