Fordson Tractors Discussion Forum
oil
ole
08-01-2004 12:29:25
shud there be oil on the fuel pump on the super dexta
if yes, where do you fill oil on the fuel pump, and how much?
Burrhead
08-02-2004 09:12:08
 Re: oil in reply to ole, 08-01-2004 12:29:25
Yes there is oil in it.
I change the oil in the pump when I change the engine oil and use the same oil in both the engine and injector pump.
You will see a drain plug in the bottom of the pump for draining the oil to change.
Looking at the pump from the side There is an oil level check plug just above and to the right of the throttle shaft.
The filler plug is the large plug located at the very front in the top, ahead of the injector line hook ups.
The capacity is 1/2 pint.
