Fordson Tractors Discussion Forum
Help, cant prime my Super Dexta
Jerry
08-12-2004 13:53:49
Hi all, My uncle gave me his super dexta and it hasnt run for a long time. The diesel had turned to varnish etc.. I had the tank cleaned and coated by a local rad shop, also put new fuel filter. My uncle told me to turn 2 little bolts on the side of the injector pump loose while pumping the prime lever to get the air out. I have done this and plenty of diesel and air comes out. I loosened one of the injector lines and cant get diesel up their at all not even while cranking engine. any help??? thanks...jerry
tractorfix
08-12-2004 15:18:34
 Re: Help, cant prime my Super Dexta in reply to Jerry, 08-12-2004 13:53:49
Did you open the plugs on top of the Fuel filter housing? Loosen the injector lines at the pump and check there. Also, make sure the small return line is clear. It should go.
jery
08-13-2004 08:16:15
 Re: Help, cant prime my Super Dexta in reply to tractorfix, 08-12-2004 15:18:34
thanks for the reply, yep did all that. do you think the old diesel might have gummed up the injector pump? any more thoughts??
