Answers to questions on SEARS LAWN TRACTORS
John S
01-30-2000 18:25:51
I would like to know if anyone has any info on the sears 20.5 hp v twin?good or bad.and there seems to be a big problem with sears transaxels why?wich trans is better for plowing snow and such? 6 speed standard or the shift on the go 6 speed ?
Randel Gray
08-19-2000 18:49:23
 Re: answers to questions on SEARS LAWN TRACTORS in reply to John S, 01-30-2000 18:25:51
Request any info. on a sears lawn tractor, 10Hp. 36in cut model and Ser# 917 255350.All I know is it is listed on the U.S. fiche # 92 29 41.Thanks
Paul
02-01-2000 11:45:20
Are you talking about a Sears tractor or a Craftsman tractor (sold by Sears). In these circles, a Sears tractor was made by AYP, had a fully welded steel frame, a horizontal, cast iron single cylinder Tecumseh engine or Onan twin, and cast iron front axle, and lasted forever. Sears tractors were last badged as Sears sometime around 1982. Craftsman tractors are not in the same league as the old Sears ones. The four speed and three with high/low tranny were almost indestructible. The old three speeds were weak. The new ones mostly have aluminum housings and are typically weak. If you're going to be plowing then spend your money on an older used tractor with cast iron axle, steel frame, and cast transaxle. I wouldn't think any of the new Craftsman tractors would stand up to a lot of abuse (though there are exceptions).
Paul
matt Finnie
01-27-2001 17:42:39
 Re: Re: answers to questions on SEARS LAWN TRACTORS in reply to Paul, 02-01-2000 11:45:20
I bought a poulan tractor from you guys and i have been needing parts and i haven't even had it for a year.now sears is coming wednesday i hope you guys repair it real good or i'm going to take it back.The thing that broke was the spindel. the welding broke off.that is the forth time it did that.
john smith
01-27-2001 17:24:26
I bought a poulan tractor from you guys and i have been needing parts and i haven't even had it for a year.now sears is coming wednesday i hope you guys repair it real good or i'm going to take it back.The thing that broke was the spindel. the welding broke off.that is the second time it did that.
