GRAVELY JUMPS OUT OF GEAR...
LINN F.
02-04-2000 01:02:33
I HAVE A 2 WHEEL GRAVELY (92 MODEL - KOHLER) THAT
JUMPS OUT OF DOUBLE LOW. WILL NOT ENGAGE INTO GEAR UNTIL TRACTOR STOPS AGAIN. ALL CONTROL SETTINGS ARE NORMAL, OIL IN X-MSN & ENGINE FINE. ANYONE ELSE HAVE THIS PROBLEM & A FIX?
Allen F. Petri
07-23-2002 19:23:39
 Re: GRAVELY JUMPS OUT OF GEAR... in reply to LINN F., 02-04-2000 01:02:33
the low range axle dog clutch on the right side needs to be remachined because it is slightly worn. I cut the clutch dogs with a slight 1-3 degree angle to prevent it from slipping out of gear.
Rich
02-04-2000 20:55:36
I've not come across this problem although have seen it posted before at the link I've given. Mine are all equipped with the Gravely engine(Nothing newer than '73). I wish I could afford a new one.
Rich
