CUB CADET 1440, Striped the transmision
Jon
02-08-2000 16:17:08
I need your help. I am stuck with a driveway full of snow and the reason is that my transmission has given out. When I move the clutch lever forward, the only thing that my 1404 does is wine. She goes in reverse but will not go forward. I checked the brakes to see if ice had built up and checked that little knob to make sure the transmission was engaged. So I came to the conclusion that I must of striped the forward drive transmission gear.
My question is do I have to drain the transmission oil or can I stand the 1440 up to work on it. Is it easy to replace the forward drive gear and should I replace all the gears since I have it apart. Any help would be greatly appreciated. Please respond before the next snowfall.
Your friend in Cubing.
Jon
Jon
02-14-2000 16:59:18
 Re: CUB CADET 1440, Striped the transmision in reply to Jon, 02-08-2000 16:17:08
I still need help
