Cold Blooded JD 325
Barn Boy
02-13-2000 06:30:25
I have a 97 325 that can sometimes be a real cold blooded SOB. I really have to choke the &4 %%% out of it to get it started when it is cold out side. Any one had similar problems ??
Thanks,
Mike
Brad
02-27-2000 21:19:01
 Re: Cold Blooded JD 325 in reply to Barn Boy, 02-13-2000 06:30:25
This 325 should have the single cyl KAW.Move the combo throttle/choke to full choke,the choke rod will be the wire with the funny bend,see if you can push it in toward the carb any distance.If you can slide it the choke screw will need to be screwed in,it is located behind the plate that the throttle cable is attached,a stubbly phillips will be required.
Good Luck!
Eric
02-13-2000 11:08:20
What kind a' engine ya got?
Eric
