Cub Cadet 1440 Transmission problem
Jon
02-14-2000 17:02:19
I need your help. I am stuck with a driveway full of snow and the reason is that my transmission has given out. When I move the clutch lever forward, the only thing that my 1404 does is wine. She goes in reverse but will not go forward. I checked the brakes to see if ice had built up and checked that little knob to make sure the transmission was engaged. So I came to the conclusion that I must of striped the forward drive transmission gear.
My question is do I have to drain the transmission oil or can I stand the 1440 up to work on it. Is it easy to replace the forward drive gear and should I replace all the gears since I have it apart. Any help would be greatly appreciated. Please respond before the next snowfall.
Your friend in Cubing.
Jon
