International Cadet
Aaron Maunumaki
02-14-2000 18:48:41
I have a early model 8 hp International Cadet.
I can't get it to start,it cranks,but won't fire.
(p.s.-i could also use a starter for one,the last one just burnt out:()
Thanks!-
chris
03-06-2000 16:08:29
 Re: International Cadet in reply to Aaron Maunumaki, 02-14-2000 18:48:41
i have a 1961 first edition tractor of international harvester cubcadet company.
the problem is i cant get it to run properly and it has blow by from the head cover and runs way to lean too much oxygen and not enough gas i need to get an engine rebuild kit for it but i dont no ware to find one this tractor has a kohler engine with a 7 or 8 horses. any suggestions or tips would be greatly apriciated thank you
David A. Sohn
02-18-2000 10:57:44
To Aaron-- from David A. Sohn
Saint Louis Missouri david.a.sohn@juno.com
Have you tested the ignition system-- using a good "0-Shaped" ignition test device? Connect it between the high tension wire and the spark plug. Confirm whether continuous, bright blue spark is jumping in the tester while the engine is spinning to start (or even if it is running). This will confirm whether or not an erratic ignition spark is part of your problem.
Unless you have already done so, you will probably need to install new points and condenser-- including the correct method of cleaning the new points following correct air- gap adjustment-- so they will work correctly.
Have you installed a new spark plug rated for the engine?
I have a 1963 Cub Cadet original myself with 7 HP Kohler engine. I mechanically rebuilt it May- June of 1999.
I hope this helps.
David A. Sohn
Janet
06-20-2000 08:02:05
 Re: Re: International Cadet in reply to David A. Sohn, 02-18-2000 10:57:44
Dave -- I, too, have an original 1963 Cub Cadet, Model 70 (7 hp kohler engine), but it has started to smoke. I was wondering if there is something I can add to the oil to help stop or curtail the smoking and need to add oil all the time.
TOM
02-15-2000 18:27:26
Are you getting any fuel to the carb?
Eric
02-15-2000 16:08:48
Aaron,
Have you checked the carberetor? They can cause your tractor to not start. If the float is stuck, then it will be flooding, or a valve may be in need of cleaning. Or it could be something totally different... I have to work on one for an old 7hp Briggs and Stratton myself....
Eric
Scott M. Harris
02-15-2000 00:39:47
Aaron,
You should check out www.ihcubcadet.com They can help you out with just about anything that concerns them older Cadets. They can even get you the parts you need.
Scott M. Harris
