Briggs I/C engines
Stephen Beaver
02-28-2000 09:32:08
Are the Briggs I/C engines worth the extra money? I have a Gilson that used to have a I/C 11HP. I put an old regular model on it, but I need a new engine, (I flooded it one time and the crankcase filled up with gas-it runs and still has power but skips a lot at low RPM). I need to know if I/Cs are worth the extra $$$.
P.S. the old engine lasted (I think) about 13-14 years before it got to knocking so bad it seemed like it was about to throw a rod.
michelle
03-03-2001 17:41:29
 Re: Briggs I/C engines in reply to Stephen Beaver, 02-28-2000 09:32:08
I have a wizard 20hp lawn mower and I need to know what type of oil I need to run in it, could any one help. Please let me know thank you..... ..... ....
p
02-28-2000 15:40:27
Are you sure the plug and ignition are in good shape. I don't think you need a new motor, but you just need to tune up the one you have....
Stephen Beaver
02-28-2000 16:32:37
 Re: Re: Briggs I/C engines in reply to p, 02-28-2000 15:40:27
I am sure that the gas in the crankcase is the problem. The crankcase was totally full of gas. (It was the carbs fault-mainly). Also, it knocks some.
Nels
02-28-2000 11:21:58
I say yes, if your Gilson is something you plan to use for a number of years yet. The I/C engines have cast iron cylinder liners and roller bearing mains, along with harder valves and seats. Larger engines also may have a syncro balance system to reduce vibrations. This saves wear and tear on the equipment it is mounted to. It is a much improved engine over the standard aluminum block.
Stephen Beaver
02-28-2000 11:29:34
 Re: Re: Briggs I/C engines in reply to Nels, 02-28-2000 11:21:58
Thanks! I guess I will be using it for a while. (I'm 13 and a JD is too expensive for now!!!) My Gilson is in pretty good shape--I need to rewire it (it is'nt charging) and get some parts for the steering. I need to rewire it so that it bypasses the "little white box" that controls the annoying safty switches.
Matt
02-28-2000 15:08:12
 Re: Re: Re: Briggs I/C engines in reply to Stephen Beaver, 02-28-2000 11:29:34
How badly is your engine burning oil. If it's not to bad you could possibly rebuild it by boring it over and putting a larger engine in it. This way you wouldn't neccesarilly have to replace your engine. I have had good success with the old 11 hp Briggs with aluminum blocks after being rebuilt. Maybe this could help you a little.
