Bolens 1402 starter problem
RJ
02-29-2000 12:47:58
Just put a new battery in my tractor. Turn ignition on and it clicks once. Try this 3 to 4 times, on and off and then it starts. Is it the starter or solenoid? Can I check each somehow to determine where the problem is? The tractor is a 14hp machine, B&S I/C engine and is 15 years old.
Thanks in advance.
Jim Krapf
02-29-2000 17:31:01
 Re: Bolens 1402 starter problem in reply to RJ, 02-29-2000 12:47:58
Try putting a heavy piece of wire #10awg or larger across the large
terminals of the solenoid.you want to do this firmly and quickly if she cranks it's the
solenoid thats bad. don't hold it there to long
it might get hot real quick if the starter is bad.
RJ
03-03-2000 04:09:19
 Re: Re: Bolens 1402 starter problem in reply to Jim Krapf, 02-29-2000 17:31:01
ok, it still will not start up. How big a job is replacing a starter? A local dealer tells me it cost about $125 plus labor.Is it something a person who changes oil/plugs can do or what. Can I get a used one to work? Thanks
Jim Krapf
03-03-2000 18:10:34
 Re: Re: Re: Bolens 1402 starter problem in reply to RJ, 03-03-2000 04:09:19
I'm not familiar with Bolens but most starters
are only a few bolts and a wire or two I'm
absolutely positive you can do this job yourself
probably in about 45min.at most.
SMB
03-09-2000 12:35:15
 Re: Re: Re: Re: Bolens 1402 starter problem in reply to Jim Krapf, 03-03-2000 18:10:34
If it's anything like a Briggs or Tecumseh, no problem! I wouldn't pay anyone $125 do to my starter! My dad and I can do about anything with a engine. You can do it! I'm 13 and learned a lot from my dad and grandpa. God Bless!
SMB
