JD212; What Year? Manual; Mower Deck
Al Burnett
03-23-2000 11:52:44
Just bought a 212 S/N M00212X286826 Want to know 1) How old is it
2) Need service manual
3) a 38" and 46" deck came with it, but I don't think either are right. At least I can't seem to make them work. Would like to find reasonable priced deck
basil corr
05-08-2004 17:58:42
 Re: JD212; What Year? Manual; Mower Deck in reply to Al Burnett, 03-23-2000 11:52:44
looking for a mower deck for john deere 212 lawn and garden tractor? can you help?
steve from mo
03-24-2000 18:41:42
I have a 210 with the 46 inch deck and I have the manuals for both the tractor and deck. There was a 38 and a 46 deck available for these, so either may be correct. The mounting of these decks is a little tricky and the manual isn't quite clear on that either.
If you still need and can't get manuals from a dealer or elsewhere, I could copy pages from mine and fax or mail them to you. I don't have a scanner.
I would suggest that, if you can, you go find someone near you who has one mounted. Look at it closely and inventory the mounting brackets and parts. You may only have one set of mounts between the two decks. You might not even have one complete set, but you can tell by comparing with one that is set up right and working.
I might be interested in buying the 38 inch deck if it is the John Deere deck. It will go through a 42-inch gate or shed door and my 46 inch deck won't.
Steve
